Allow Protected text to have its style changed.
vizualweb
Post by vizualweb »
Hi All,
I'm using a protect text style to insert mail merge fields into a TRichViewEdit.
The following code works perfectly...
LetterRichViewEdit->CurTextStyleNo = 1; //TextStyle modify protected
LetterRichViewEdit->InsertStringTag(myField, myField);
Now using manual code to apply say BOLD...
TSpeedButton*Button = (TSpeedButton*)Sender;
LetterRichViewEdit->ApplyStyleConversion(Button->Tag);
If I there is normal text either side of the protected field and I select the text and the protected text and then apply BOLD to it, the protected field changes to bold also ("perfect" that's what I want)
But then if I try using an ActionList to apply BOLD in the same way, the BOLD is only applied to the normal text either side and NOT to the protected field.
Since I want to use ActionList as its far quicker and easier, then how can I allow the protect field to also have its style changed (i.e bold, italic, underline, colours etc).
I can do this using manual code, but maybe there's a way for ActionList to get around this.
I did trying playing with the MailField Text Style Protection properties, but it didn't seem to make a difference.
As you can imagine, when a person is editing their mailmerge document, they want to be able to apply styles to all text including protected mail fields, so if I can do that using ActionList and some settings in the style protection properties then perfect, but does anyone know?
Thanks ;)
vizualweb
Worked it out...
Post by vizualweb »
I found that I did have the correct protection options setup, but I had the styles being loaded in from the TDBRichView and overwritting my changes to the Styles protection...
So all working now.
