Cells longer than a page length
BrettM
Post by BrettM »
Hi
We are currently using version 1.8.14.1 of the RichView components. They are working well however we do have an issue when printing where the cell length in a table is greater than the page length. It appears as if the cell continues to be printed but off the end of the page. In later versions of the components does the cell split over two pages if the cell is longer than a single page when printing? Or is the behaviour the same as we have encountered?
Cheers
Brett
Page breaks inside cells are not implemented yet, but it will be the first next major feature implemented.
peke
Post by peke »
And can you tell us when the major release will be out?
When sufficient amount of new features will be implemented :)
But, since TRichView updates are free for registered users, major updates have only a symbolic meaning.
peke
Post by peke »
I understand you ;) but is it possible to tell us when we can use pagebreaks inside cells during printing? This is my the biggest problem with TRichView, I have to use IE for print preview and print, which is not the solution I want :(
Sorry, no. As soon as it will be possible.
