Use according to PrintSRV (SRichViewEdit1);
Ceprotec
Post by Ceprotec »
So, is shown to the User, Text Box Printing IMG as I'm sending you to analyze.
I wonder what the command or function of the RichView I use to see if the User clicked ok to PRINT?
or click the CANCEL button to print the document?
How do you display this dialog?
Ceprotec
Post by Ceprotec »
Pelo uso PrintSRV(SRichViewEdit1) do Richview;
Quando eu uso essa função do Richview, ele me mostra essa caixa de diálogo
Nela tenho 2 botões a saber:
O primeiro é o botão OK que dispara a impressão do documento.
O segundo é o botão de Cancelar a impressão.
A pergunta é, qual é o comando ou função do richview para que me informe se o usuario clicou no botão OK ou no botão Cancelar ?
Ceprotec
Post by Ceprotec »
By using PrintSRV (SRichViewEdit1) of Richview;
When I use this function of Richview, it shows me this dialog box
In it I have two buttons namely:
The first is the OK button that triggers the printing of the document.
The second is the Cancel button to print.
The question is, what is the command or function RichView to let me know if the User clicked the OK button or the Cancel button?
Sorry, what is PrintSRV, in which unit is it defined?
