update all image
cychia
update all image
Post by cychia »
how can i update all images in the content to stay in its own line? for example, this is my content:
abc[picture]xyz
i want it to be:
abc
[picture]
xyz
Assuming that this operation do not need to be undone:
uses RVTable, CRVData;
procedure MoveImagesToNewLine(RVData:TCustomRVData);
var i,r,c: Integer;
    Table: TRVTableItemInfo;
    case RVData.GetItemStyle(i) of
      rvsPicture, rvsHotPicture:
          if (i>0) and (RVData.GetItemStyle(i-1)<>rvsListMarker) then
            RVData.GetItem(i).SameAsPrev := False;
          if i+1<RVData.ItemCount then
            RVData.GetItem(i+1).SameAsPrev := False;
      rvsTable:
          Table := TRVTableItemInfo(RVData.GetItem(i));
          for r := 0 to Table.RowCount-1 do
            for c := 0 to Table.ColCount-1 do
              if Table.Cells[r,c]<>nil then
                MoveImagesToNewLine(Table.Cells[r,c].GetRVData);
procedure TForm3.ToolButton68Click(Sender: TObject);
  RichViewEdit1.ClearUndo;
  MoveImagesToNewLine(RichViewEdit1.RVData);
  RichViewEdit1.Format;
cychia
Post by cychia »
Sergey Tkachenko wrote:Assuming that this operation do not need to be undone:
var i,r,c: Integer;
      rvsTable:
it works, but i need one more changes to the image para which is alignment will be changed to rvaCenter.
Do you want to keep all other paragraph properties (such as indents or background) and simple make this paragraph centered?
Or may be you want to apply some specific paragraph style (centered, no indents, no background color, etc.)
cychia
Post by cychia »
Sergey Tkachenko wrote:Do you want to keep all other paragraph properties (such as indents or background) and simple make this paragraph centered?
now the picture is on para of its own right? i want the picture to be aligned to center. there will no other things are allowed in the same para with the picture
