Problem with HTMLViewImporter
CyberMuth
Post by CyberMuth »
I have a problem with the htmlviewimporter.
I would like import a HTML File in the TRichViewEdit and i use the htmlviewimporter with the htmlviewer. The html includes pictures.
I use the following code:
if OpenDialog1.Execute then begin
    HTMLViewer1.Base := OpenDialog1.FileName;
    HTMLViewer1.LoadFromFile(OpenDialog1.FileName);
    RVHTMLViewImporter1.ImportHtmlViewer(RichViewEdit1);
    NormalizeRichView(RichViewEdit1.RVData);
    RichViewEdit1.Format;
The pictures are in the same folder as the html file.
This is the image tag in the html-file:
<IMG alt="TS - Conditioned time signal" src="test.jpeg" width=640 height=390>
The problem is, I can't import the pictures in the richviewedit because I get a error. The importer use a wrong path for the image.
What can I do?
Please send me this HTML with images to richviewgmailcom
CyberMuth
Post by CyberMuth »
i have send a email.
CyberMuth
Post by CyberMuth »
what is the right email adress???
CyberMuth
Post by CyberMuth »
I have the problem solved.
Before import the HTML you must use the folowing code:
SetCurrentDir(ExtractFilePath(m_sIndexHTMLPath));
Assigning
HTMLViewer1.BasePath := ExtractFilePath(OpenDialog1.FileName)
before loading must help.
Making the HTML file's directory current does not help if images are in subdirectory.
