TDBRichViewEdit, tags and plain text question
abranquart
Post by abranquart »
Hi guys,
I need some help to implement TDBRichViewEdit on my new project :
I will use TDBRichViewEdit in “mail merge” mode, users will enter plain text, add variables/tags that was identifies by a code but users will saw a text in the editor (ex: Tag = {TAG01], Text = “<Some text>”).
At this point, everything is ok, I’m using InsertStringTag(“<Some text>”, “{TAG01}”) and it’s fine, but I need to store the text in database in text format for SQL manipulations (String replace of tags from SQL stored procedure).
I have two choices, and I have one question for each :
1. I can store text twice, one field in RVF format (for GUI editing) and another one in TXT format (for SQL manipulation), but how can I get a plain text string with tag names.
Example :
Text in TDBRichViewEdit : “Here is the <Some text>”
Plain text wanted : “Here is the {TAG01}”
I try using function GetAllText but it returns “Here is the <Some text>”
2. Is it possible to store plain text in database, and reload it but creating tags ?
Text stored in DB must be : “Here is the {TAG01}”
Text displayed in TDBRichViewEdit after load : “Here is the <Some text>” (tags must be created)
Thank a lot for your help.
It can be implemented either by creating your own text saving procedure, or by processing OnSaveItemToFile event.
I'll try to make an example in this weekend.
abranquart
Hi Sergey !
I’m using labels now (TRVLabelItemInfo) for better user usage.
I have adapted the GetFormattedText that you wrote here http://www.trichview.com/forums/viewtop ... mattedtext to get the plain text result with labels/tags.
What I’m missing now, is an example of how to load plain text with labels/tags (“{TAG01}”) and replace it by real labels/tags in TDBRichViewEdit.
Thanks a lot.
The most similar demo to your request is http://www.trichview.com/support/files/ ... -text4.zip
This demo uses plain text fields (inside {}), and allows inserting different types of field values (text, picture, table).
To insert label item instead of other types of items in this demo, change TForm1.InsertField:
procedure TForm1.InsertField(RVData: TCustomRVData;
  var ItemNo, Pos: Integer; const FieldName: String);
var LabelItem: TRVLabelItemInfo;
  LabelItem := TRVLabelItemInfo.CreateEx(RVData, RVData.GetItemStyle(ItemNo), FieldName);
  LabelItem.Tag := FieldName;
  InsertItem(RVData, ItemNo, Pos, LabelItem);
