TrvActionFind dialog switching focus on Close
hejsan
Post by hejsan »
I am using the TrvFindAction to open a dialog and find text in a TRichViewEdit v13.6.2, and encountered a possible bug(?); whenever I click Close or "x" (Windows 7 64-bit), the find dialog disappears as expected, but the entire parent form application loses focus and switches to another open Windows 7 window. What could be the possible cause for this issue?
Thank you.
Does it happen if you call TFintDialog.Execute without an action?
hejsan
Post by hejsan »
Sergey Tkachenko wrote:Does it happen if you call TFintDialog.Execute without an action?
Yes I tried it now and it does happen if I call it without an action..
It looks like a general Delphi XE2 problem...
hejsan
Post by hejsan »
Sergey Tkachenko wrote:It looks like a general Delphi XE2 problem...
Yes it seems like it is not an issue with RichView at all. Thanks for your help anyway.
