bug? reload RVF SRVCombobox control height changed
I insert SRVCombobox into RVF doc and set the srvcombobox control height with new value(< default value) . save it . but the control height changed after reload this rvf doc.
Yes.Sergey Tkachenko wrote:Did you set SRVComboBox.Autosize = False?
procedure TfrmAppMain.InsertComboboxControl(RVEdit: TCustomRichViewEdit; ctrlname: string; ItemWidth: Integer; Items: TStrings);
c_combobox: TSRVComboBox;
i, w: Integer;
c_combobox := TSRVComboBox.Create(nil);
c_combobox.Name := ctrlname;
c_combobox.DropDownCount := 12;
c_combobox.AutoSize := False;
c_combobox.Width := ItemWidth;
c_combobox.Height := 15;
c_combobox.AutoDropDown := True;
c_combobox.Style := csDropDownList;
c_combobox.Font.Size := 9;
c_combobox.Edit.Font.Assign(c_combobox.Font);
c_combobox.Parent := RVEdit;
w := 0;
for i := 0 to Items.Count - 1 do
c_combobox.Items.Assign(Items);
RVEdit.InsertControl(ctrlname, c_combobox, rvvaAbsTop);
c_combobox.Update;
I cannot reproduce this problem.
I tested in the InsertControl demo: added the code:
When copy-pasting a combobox (it must be the same as loading), it is inserted with the same height, 5 pixels.
(however, there is a glitch in redrawing after pasting, it disappears after mouse movement, we will fix it)
May be you use an old version of ScaleRichView?
c.Autosize := False;
c.Height := 5;
