Saving an RTF
afusco
Saving an RTF
Post by afusco »
I'm not sure where the issue is - scalerichview, richview or richaction. I am using the following demo as a base that shipped with scalerichview (ScaleRichView\Demos\ActionTest).
If I load an RTF file and then go to save it, I get the following message: "xxxx.rtf may contain features that are not compatible with the chosen saving format. Do you want to save the document in this format?"
I'm assuming this is because it wants to save the file as a RVF by default.
I am only working with RTF and don't want to save/load a RVF file. Since I am only loading RTF files and saving them back as RTF is there anyway to set this as a default and get rid of the confirmation "error" generated above? There are so many properties, I can't seem to find an obvious default file default as RTF.
Exclude ffeRTF from rvActionSave.LostFormatWarning property.
