Protect a word or paragraph
alexandreq
Post by alexandreq »
Hello sergey
I am trying to add a resource in my editor, protect functions.
First, is there any action that does this?
If not, I tried this code:
procedure TForm1.rveStyleConversion(Sender: TCustomRichViewEdit; StyleNo,
  UserData: Integer; AppliedToText: Boolean; var NewStyleNo: Integer);
var FontInfo: TFontInfo;
  FontInfo := TFontInfo.Create(nil);
    FontInfo.Assign(rvs.TextStyles[StyleNo]);
    case UserData of
      TEXT_PROTEGE:
        FontInfo.Protection := [rvprModifyProtect];
      TEXT_BOLD:
        if btnBold.Down then
          FontInfo.Style := FontInfo.Style+[fsBold]
          FontInfo.Style := FontInfo.Style-[fsBold];
    NewStyleNo := rvs.TextStyles.FindSuchStyle(StyleNo,FontInfo,RVAllFontInfoProperties);
    if NewStyleNo=-1 then begin
      rvs.TextStyles.Add;
      NewStyleNo := rvs.TextStyles.Count-1;
      rvs.TextStyles[NewStyleNo].Assign(FontInfo);
      rvs.TextStyles[NewStyleNo].Standard := False;
    FontInfo.Free;
procedure TForm1.rveCurTextStyleChanged(Sender: TObject);
var fi: TFontInfo;
  IgnoreChanges := True;
  btnBold.Down      := fsBold      in fi.Style;
  btProtege.Down    := fi.Protection = [rvprModifyProtect];
  IgnoreChanges := False;
But this not working, something I forgot?
thanks
This protection text must protect the selected text from modification. But it does not protect
- from deletion it as a whole
- from changing its text style to another style
- from switching the current text style to this style and insertion of new characters of this style before/after the protected fragment (since this fragment cannot be modified, the inserted character will not be combined with it, so each typed character will create a new single-character text item)
As for buttons, if you use TSpeedButton or an analog, do not forget to assign non-zero GroupIndex and AllowAllUp=True.
