Load and save PNG in TDBRichViewEdit extremely slow
Joe
Post by Joe »
Hello Sergey,
Windows 7, Delphi 2010, RichView 13.8
First of all: TDBRichViewEdit works great!
Now my problem:
When loading a PNG graphic (160 KB) into the TDBRichViewEdit (with a simple line of text) and saving the record this takes 62 seconds! Loading takes 20 seconds.
With Paint I converted the PNG graphic to a JPEG which then has a size of 387 KB. Saving in the identical record takes less than 1 second, and also loading is not measureable.
In the support forum I found hints to use:
Classes.RegisterClass(TPngImage);
CRVData.RV_RegisterHTMLGraphicFormat(TPngImage);
CRVData.RV_RegisterPngGraphic(TPngImage);
I tried all that, but it makes no difference. Must I set some addional flags (e. g. rvrtfSaveBitmapDefault) or something like that?
Do you have any advice?
Thanks in advance
Joe
What's the saving format? RTF or RVF?
Can you send the field content with this PNG (saved as a file using BlobField.SaveToStream(FileStream) to richviewgmailcom?)
Joe
Post by Joe »
Hello Sergey,
the field format is rvdbRVF.
All further information is now send to you by email.
Best regards
Joe
Answered by email.
Joe
Post by Joe »
Very detailed information! Great support!
Thank you
Joe
Ruediger Kabbasch
Post by Ruediger Kabbasch »
Is it possible to provide the information to the public?
With kind regards,
Ruediger Kabbasch
Joe
Post by Joe »
Hello Ruediger,
yes, of course it might be interesting to the public. The problem was caused by the datatype! of the underlying database field.
In this context I ran into another problem, caused by the datatype, too.
See my last answer in the following topic:
http://www.trichview.com/forums/viewtopic.php?t=5379
Best regards
Joe
Ruediger Kabbasch
Thanks!
There were 2 problems
1) Because of "Unicode memo" field type, data were saved as RTF converted to Unicode string. Pictures in RTF ==> twice in size. RTF to Unicode string ==> twice in size. As a result, a picture is increased by 4 times from the original size.
2) Due to property setting or due to the insertion methods, the picture was saved not as PNG but as a metafile containing bitmap (large size).
