Find in TDBRICHVIEWEDIT
jota
Post by jota »
Hello.
I need to define a search on data in tdbrichviewedit, containing information from a blob field. I want to place cursor in text found.
How can I do?.
Thanks in advance.
Search for a substring? Use SearchText method.
jota
Post by jota »
Hi
I always do the search from the beginning TDBRichViewEdit text, even if the cursor is in the middle or end of the text
How can I do?
Thank in advance
Store the selection (RVGetSelectionEx from RVLinear.pas), move the caret to the beginning (dbrv.SetSelectionBounds(0, dbrv.GetOffsBeforeItem(0), 0, dbrv.GetOffsBeforeItem(0)), search. If not found, restore the original selection (RVSetSelectionEx).
You can also store and restore scrolling position (VScrollPos)
