Install Editors for DevExpress in Delphi 7
Juergen
Post by Juergen »
I have an problem installing the Editors for DevExpress in Delphi 7.
Is there any package for Delphi 7 out there?
Thanks in advance.
Juergen
Create a new package, save it as cxRVEditorsD7.dpk, add pas-files into it. Install.
Juergen
Post by Juergen »
Thanks, this works fine.
I had only one problem: in file cxTRichView.pas the unit dxCoreClasses was used what is not included in Developer Express Components with Installer 1.58.
When one comment out dxCoreClasses the package compiles and work as expected.
