Hello Sergey,
When I change the Page Size with srvActionPageFormatA4 to srvActionPageFormatA5, I noticed that the configuration is not saved with my page.
I use DBSRichViewEdit with table.
For Example: If I change the A4 to A5 and when I close the form and open it once again, the same old configuration is loaded.
But when I run srvActionPageSetup1 and change the A4 to A5 for example, I notice that the browse state is changed to dsEdit and it is keep the changed.
Wouldn't it keep the change in my page?
Alexandre
Help - Page Size From A4 to A5 changing.
In the current version of ScaleRichView, assigning PageProperty is not an editing operation, so the dataset is not informed about the change.
Use the code from http://www.trichview.com/help/idh_examp ... edit1.html , change DBRichViewEdit1 to DBSRichViewEdit1.RichViewEdit.
