problem with action script when I have more than 1 DBSRich..
alexandreq
Post by alexandreq »
Hello Sergey,
I have a form with 3 DBSRichViewEdits and when I use this actions:
srvActionOrientationPortrait1,
srvActionOrientationLandscape1,
srvActionEditHeader1,
srvActionEditFooter1
the actions don't execute the correct option on the correct selected (focused) component.
For example
If the focus is on DBSRichViewEdit1, the actions gets another DBSRichViewEdit, it doesn't apply the change in the DBSRichViewEdit correct.
Alex
Please send a sample project to reproduce to richviewgmailcom
alexandreq
Hello Sergey,
I was preparing an example to send to you then I noticed something very interesting.
Let me explain.
In my project I use the suipack component for skin from http://www.sunisoft.com, I noticed when I have my DBSrichViewEdit on Suipagecontrol, it gets crazy the action script.
If I Use pagecontrol from Delphi, it works fine.
Why? I am sending to you an executable file so that you take a look at it.
thanks
I did not receive the email, but I can suggest a solution.
When a TSRichViewEdit gets the input focus (OnEnter event), assign:
RVAControlPanel1.DefaultControl := FocusedSRichViewEdit.RichViewEdit;
srvActionOrientationPortrait1.Control := FocusedSRichViewEdit;
srvActionOrientationLandscape1 := FocusedSRichViewEdit;
alexandreq
thanks sergey.
I did what you asked me to do and works.
What does this component do RVAControlPanel1? Must I have it in any project?
TRVAControlPanel allows changing some settings.
See http://www.trichview.com/help-actions/t ... lpanel.htm
Actually, assigning to its properties changes values of some global variables, so it does not make sense to have more than one TRVAControlPanel in a project.
This component is not necessary if you do not want to change settings.
