How do I save/load a page format
vit
Post by vit »
How do I save/load a page format (orientation, margins, size etc)?
I store document in the way:
procedure TDocEditFrame.SaveFile(const FileName: string);
  fs: TFileStream;
  fs := TFileStream.Create(FileName, fmCreate or fmOpenWrite);
    SRVE.RVHeader.SaveRVFToStream(fs, False);
    SRVE.RVFooter.SaveRVFToStream(fs, False);
    SRVE.RichViewEdit.SaveRVFToStream(fs, False);
    fs.Free;
And load:
procedure TDocEditFrame.LoadFile(const FileName: string);
  fs: TFileStream;
  fs := TFileStream.Create(FileName, fmOpenRead);
    SRVE.RVHeader.Clear;
    SRVE.RVFooter.Clear;
    SRVE.RichViewEdit.Clear;
    SRVE.RVHeader.LoadRVFFromStream(fs);
    SRVE.RVFooter.LoadRVFFromStream(fs);
    SRVE.RichViewEdit.LoadRVFFromStream(fs);
    SRVE.RVHeader.Format;
    SRVE.RVFooter.Format;
    SRVE.RichViewEdit.Format;
    SRVE.SetRVMargins;
    fs.Free;
But the page format doesn't appear.
I'm aware I need to handle TRVAControlPanel.OnMarginsChanged and call SRVE.SetRVMargins from inside. But this event doesn't fire.
So what should I do to save/load the page format?
Saving:
SRVE.RichViewEdit.SaveRVF(FileName, False);
(you can use TFileStream and SaveRVFToStream, but it is not necesary).
Loading:
SRVE.Clear;
SRVE.RichViewEdit.LoadRVF(FileName);
SRVE.Format;
Important: use Clear and Format methods of SRVE itself.
Note: TRVAControlPanel.OnMarginsChanged must be used only if loading is made using TrvActionOpen.
