How to recognize delimited word and replace with a new word
Would it be ok if keywords will be hyperlinks? If yes, can this document contain other types of hyperlinks, such as URLs?
Here is the example of what you asked originally.
When the user clicks any text inside [], it selects it (including []), displays some form (a message box in this test) and replace it to a new value.
This demo uses OnRVMouseUp event.
Limitation: this keyword, including [], must be written using the same font.
function SelectFld(rve: TCustomRichViewEdit): Boolean;
var s: String;
    ItemNo, Offs, Offs1, Offs2: Integer;
  Result := False;
  if rve.SelectionExists then
  rve := rve.TopLevelEditor;
  ItemNo := rve.CurItemNo;
  Offs := rve.OffsetInCurItem;
  if (rve.GetItemStyle(ItemNo)<0) or
     (Offs<=rve.GetOffsBeforeItem(ItemNo)) or (Offs>=rve.GetOffsAfterItem(ItemNo)) then
  s := rve.GetItemText(ItemNo);
  Offs1 := Offs;
  while (Offs1>=1) and  (s[Offs1]<>'[') do
    dec(Offs1);
  if Offs1<1 then
  Offs2 := Offs;
  while (Offs2<=Length(s)) and (s[Offs2]<>']') do
    inc(Offs2);
  if Offs2>Length(s) then
  rve.SetSelectionBounds(ItemNo, Offs1, ItemNo, Offs2+1);
  Result := True;
procedure TForm3.RichViewEdit1RVMouseUp(Sender: TCustomRichView;
  Button: TMouseButton; Shift: TShiftState; ItemNo, X, Y: Integer);
  if SelectFld(RichViewEdit1) then begin
    Application.MessageBox(PChar('Here you can display a form to edit '+RichViewEdit1.GetSelText), 'Test', 0);
    RichViewEdit1.InsertText('New value');
You can change text attributes of the selected text.
Do you use RichViewActions? They allow to do it in a very simple way.
Otherwise, you need to use OnStyleConversion event and ApplyStyleConversion method, see the demo in Demos\*\Editors\Editor 2\.
