Hi.
I need present plain text from a blob field, in a dbgrid component (really, an small portion of every blob field).
It´s saved with rvf format.
Can anyone help me
Thank in advance.
Plain text from blob field with rvf format
You need to load this field in TRichView/TDBRichView component and then save as text.
For loading, you can either link TDBRichView to this field, or use TRichView.LoadRVFFromStream (see Demos\*\DB Demo\2 RichViewEdit)
For saving, you can, for example, use GetAllText from RVGetText unit (or from RVGetTextW unit, if you need Unicode text).
If you download a trial version, it includes RVGetTextW.dcu.
Help on this unit: http://www.trichview.com/help/idh_rvgettext.html
