Persistent Reference to an Image
Mark Andrews
Post by Mark Andrews »
I have a TRichViewEdit that contains an invisible table with multiple cells. Two of the cells each contain an image and I'd like to do the following:
When the user resizes the image in one cell it causes the image in the other cell to automatically resize.
It seems I could do this easily if I could obtain a persistent reference to each image at the time they are pasted or inserted.
Is such a thing possible or can anyone recommend an alternative?
For example, you can assign an unique identifier to the image item text, and search the image by its identifier... Would this solution be ok?
But I do not understand how you want to define these images, if they can be either inserted or pasted...
