How can I work with two dictionary and exchange them?
alexandreq
Post by alexandreq »
Hello Sergey,
I am testing the power of dxSpellCheck (from DEV) and DBSrichViewEdit.
On my form I have two DBSrichViewEdits, the first one I am gonna write english words and the second the portuguese words.
I loaded two dictionary and I need to change it when I click on the DBSrichViewEdit.
So
If I click the first DBSRich I need to change the dictionary to english
If I click on the seconf DBSrich I need to change the dictionary to Portuguese
How can I do this? Is It possible to exchange them by code?
Alex
I asked DevExpress developers, they said that probably you can use Enabled property of a dictionary to activate/deactivate it.
You can try doing it either in OnEnter of the editor, or in spellchecker.OnBeforeCheck.
