How to keep the margins configuration in the file
Hello Sergey,
When I give a double click on margins it calls this code:
srvActionPageSetup1.ExecuteTarget(Editor);
When I change my page configuration, for example, from landscape to portrait or vice versa, the new parameters page is not keept in my db.
When I close the system and open it again, my page returns to the same configuration and didn't keep my preferences.
What is wrong with this code? Something missing? I notice when I change the page configuration, my db state doesn't change to dsedit, for example.
Open SRVActions.pas, find TsrvActionPageSetup.ExecuteTarget.
Changeto
This fix will be included in the next update.
Change
frm.Apply(Edit);
if Edit.RichViewEdit.CanChange then
frm.Apply(Edit);
I didn't find the SRVActions.pas, only RichViewActions,
My version is 12 and the code that I have inside the procedure is:
procedure TrvActionPageSetup.ExecuteTarget(Target: TObject);
var frm: TfrmRVPageSetup;
frm := TfrmRVPageSetup.Create(Application);
if MarginsUnits=rvpmuInches then
frm.UseInches;
if frm.Init and (frm.ShowModal=mrOk) then begin
frm.Apply;
if Assigned(FOnChange) then
FOnChange(Self);
frm.Free;
When I tried to add your code, Delphi doesn't find the Edit.
What Can I do?
I also call this code when I give double click on the margins, when I do this, I run this code:
Maybe can it be worked around here?
thanks
frm.UseInches;
frm.Apply;
FOnChange(Self);
frm.Free;
What Can I do?
thanks
