Hello sergey
I did this code to create several checkpoints.
str : string;
Editor : TDBSRichViewEdit;
PegaEditor(Editor); // get the active editor
str := Editor.RichViewEdit.GetSelTextW;
if str='' Then Begin
ShowMessage('No word to create checkpoint');
end else begin
if Editor.RichViewEdit.CanChange Then Begin
Editor.RichViewEdit.AddNamedCheckpoint(Str);
Editor.RichViewEdit.Format;
Qtextos.Post;
CarregaCheckPoint; // procedure Load CheckPoints into a listbox
I am having the following problem:
1) I can only create one checkpoint
2) My text isn't being save with checkpoint created.
Why?
problem with checkpoint - add
1) A checkpoint mark a position in the document. It cannot mark a selected fragment or any range of text.
2) AddNamedCheckpoint adds a checkpoint to the end of the document.
I recommend using InsertCheckpoint, GetCheckpointAtCaret, RemoveCheckpointAtCaret methods. They are editing methods, so you do not need CanChange, Format. Post is optional, if you want to save changes to DB immediately.
