Hello Friend,
I am using your function to remove all formatting.
When I did it, I notice that it was done only on the screen.
How to save this changed in table with the text?
thanks
Removing formatting with DBSRichViewEdit1
See http://www.trichview.com/help/idh_examp ... edit1.html
Insert your code for clearing text format instead of
DBRichViewEdit1.Clear;
DBRichViewEdit1.LoadRTF(OpenDialog1.FileName);
Use this code:
Or, if you want to save changes immediately:
DBRichViewEdit1.CanChange activates table editing, it makes table state = dsEdit
if DBRichViewEdit1.CanChange then begin
<your code for clearing formatting here>
DBRichViewEdit1.Change;
DBRichViewEdit1.Format;
Table1.Post;
