when richview support Firemonky?
gbg
Post by gbg »
We plan to start this work after releasing TRichView 14, later in this year.
But I do not know how long it will take. And it will be a separate product.
CristianP
Post by CristianP »
Sergey Tkachenko wrote:We plan to start this work after releasing TRichView 14, later in this year.
I plan to move my main application to FireMonkey but I use now RTF in FastReport because I need formated text and sometimes images inserted in this text.
Is FireMonkey version still in plan?
Best regards,
Cristian Peța
Not in this year, sorry.
There are some things that we want to release before: http://www.trichview.com/forums/viewtopic.php?t=5659
CristianP
Post by CristianP »
Mid next year it will be perfect.
Hopefully Embarcadero will release iOS and Android compilers, maybe then will be FastReport for FireMonkey out of beta and I can write new FMX interface for my engine.....
I hope.....
And I checked your link but there is no topic 5659 in this forum.
Best regards,
Cristian Peța
Sorry, that post was in the forums for registered users.
If you are a registered user, please send me a private message with details of your order (for example, email address used in it), and I'll open access to the protected forums.
Briefly, we have the following plans:
- releasing TRichView 14 & ScaleRichView 5 (soon, we just need to update help and demos)
- releasing RVMedia
- implementing HTML import without additional components,
- releasing ActiveX version of TRichView.
Only after that, we plan to start FM work.
CristianP
Post by CristianP »
Thanks for the info.
I am not registred user. In Windows Rich Edit wrapers is enough for me.
I found TRichView because I want to switch to FM (iOS, Android and I hope Linux) and I want embeded images. HTML do not embed images and I do not found native Delphi HTML renderer that can be converted to FM and then included in FastReport.
FireMonkey implementation of TRichView will perfect for me.
Best regards,
Cristian Peța
PetterT
Post by PetterT »
Hi Sergey.
When do you expect a release of the Firemonkey version of TRichView?
Petter
When it will be ready. Sorry, I cannot tell yet.
AtomPark
Post by AtomPark »
Очень интересует компонент RichViewEdit для Firemonkey. Когда можно ожидать релиза?
FM work is still not started, sorry
