How to save the margins configuration ?
alexandreq
Post by alexandreq »
Hello
I am using dbrrichview with access database.
I setup all the margin configuration for my document and when I save it into my table I want to save all the margin configuration for it too. Is it possible?
Another thing
When I browse my table, it is possible to show my doc according as they were saved, with margin configuration.
thanks
Alex
Include rvfoSaveLayout and rvfoLoadLayout in DBRichViewEdit.RVFOptions.
Note: when you change margins in code, follow the instructions from http://www.trichview.com/help/idh_examp ... edit1.html , e.g.
if DBRichViewEdit1.CanChange then begin
  DBRichViewEdit1.LeftMargin := 10;
  DBRichViewEdit1.Change;
  DBRichViewEdit1.Format;
alexandreq
Hi Sergey
Yeah, both options are true.
When I change the margins in the ruler, my table doesn't keep the margins configuration and when I open the text again, it is displayed with the same margin default.
If you could give me an example with your database example I thank you very much.
What's the value of DBRichViewEdit.FieldFormat ?
alexandreq
It is rvdbRVF.
Sergey,
is it possible you give me an example with your own example that uses table?
I noticed your component brings some database examples, but no one with ruler. It would be wonderful to have an example where the docs are kept with all margins configurated and when displayed the text, the ruler is settled at the right position when the text was produced.
thanks
Just use DataSet.AfterScroll:
procedure TForm1.Table1AfterScroll(DataSet: TDataSet);
  RVRuler1.UpdateRulerMargins;
If it does not help, I'll create a demo.
alexandreq
Solved - Thanks very much.
