font qulalitiy
amethyst623
font qulalitiy
Post by amethyst623 »
is there a method to set the font quality for text in the richviewedit?
LOGFONT logFont;
logFont.lfHeight = 8;
logFont.lfWidth = 0;
logFont.lfEscapement = 0;
logFont.lfOrientation = 0;
logFont.lfWeight = FW_NORMAL;
logFont.lfItalic = 0;
logFont.lfUnderline = 0;
logFont.lfStrikeOut = 0;
logFont.lfCharSet = ANSI_CHARSET;
logFont.lfOutPrecision = OUT_DEFAULT_PRECIS;
logFont.lfClipPrecision = CLIP_DEFAULT_PRECIS;
logFont.lfQuality = PROOF_QUALITY;
There are no direct properties for changing a font quality.
A solution is possible using TRVStyle.OnApplyStyle event:
// code for RVStyle.OnApplyStyle event
procedure TForm1.RVStyle1ApplyStyle(Sender: TRVStyle; Canvas: TCanvas;
  StyleNo: Integer; var DoDefault: Boolean);
var LogFont: TLogFont;
    tm: TTextMetric;
    TextStyle: TFontInfo;
  DoDefault := False;
  TextStyle := Sender.TextStyles[StyleNo];
  TextStyle.AssignToLogFont(LogFont, Canvas, True, False, False);
  LogFont.lfQuality := 3 {NONANTIALIASED_QUALITY};
  Canvas.Font.Handle := CreateFontIndirect(LogFont);
  // supporting CharScale property
  if TextStyle.CharScale<>100 then begin
    if GetTextMetrics(Canvas.Handle, tm) then
      LogFont.lfWidth := tm.tmAveCharWidth*TextStyle.CharScale div 100
      LogFont.lfWidth := Canvas.TextWidth('x')*TextStyle.CharScale div 100;
  // supporting CharSpacing property
  SetTextCharacterExtra(Canvas.Handle, TextStyle.CharSpacing);
This solution has the following problems:
1) it applies only to text; bullet and numbering still use the system settings
2) this solution ignores bidirected text properties, so it can be used only if your application does not need to support Arabic or Hebrew.
