Table
xmedia
Table
Post by xmedia »
is it possible to associate a custom object (to store some custom informations) to a table item or a table cell. if yes how ?
You can encode any additional information in the table tag. You can get it as GetItemTag/SetItemTag, or simply as table.Tag. This is a string.
If you need some object associated with the table, implement saving and loading it to/from string, and save/load it to/from tag.
