FastReport wapper
LadyOfWood
FastReport wapper
Post by LadyOfWood »
Any news about it?
dkounal
Re: FastReport wapper
Post by dkounal »
LadyOfWood wrote:Any news about it?
I got a zip from fastreport's creator but I can not attach it to this forum.
Try to search a message with subject "trichview printing from fast-report" in the newsgroups of fastreport v3
LadyOfWood
I see this file they require unknown units MemDS, IntfECDbFields, ECDBFields, and i think it rather incomplete.
dkounal
Post by dkounal »
LadyOfWood wrote:I see this file they require unknown units MemDS, IntfECDbFields, ECDBFields, and i think it rather incomplete.
memDS probably exists in lazarus and for the others I do not know from where they can from.
From a very fast view in the source, I noticed that you can leave them out if you find a way to unzip the rvstream in line 258 of frxDocRichview and convert the IECstream to Tmemorystring.
Also, it does not work with TfrxUserDataset type datasets but only with TfrxDBdataset that that is a big problem for me since I am using only tfrxuserdatasets with XML tables and databases.
You have right, it is still incomplete and does not free a lot of things, but it is a point to start. And I need a wrapper for my trichview in fastreport me too, because all my printing is based on fastreport but Sergey told about August, so, I am still waiting.
LadyOfWood
August soon end, i think Sergey can say where can he write this wapper.
visitor
Post by visitor »
Any feedback about it ?
That was only plans, about August.
It will be implemented as soon as it will be possible, but some other features come first
Guest
Post by Guest »
Thank you, i guess that some of us are "really" waiting for it :)
LadyOfWood
Any news about it? When they will be implemented (may be first beta or ....) or this task never will be done.
The answer is the same. It will be implemented, but this work is not started yet, and I cannot tell the date because I do not want to misguide you.
LadyOfWood
Is any chance that this work will be started. What position are they have in current roadmap.
gully
Post by gully »
Hello Sergey.
Any feedback about FastReport Wapper ?
Thanks for Your answer.
Still no news.
But the next release is almost ready, after it I will be able to start working on new problems like this wrapper.
gully
Post by gully »
Hello Sergey.
Sorry for my recrudescent answer :D
After completing all work related to the last release (yes, it's not finished yet), I plan to implement saving headers and footers in RTF (not too difficult and was promised long ago).
Then I'll need to choose the next step: FR, or improvements in formatting (including left and right picture align), or loading HTML using thirdparty (pbear's wrapper).
