Hi I'm trying to use existing (modified) ribbon example as dll, so other apps can use it. When I build it as exe everything works.
But if I make a dll, ribbon form opens up, but then nothing works. Actions are not working, example: set font to bold.
I tried to manually enable this actions but no luck.
There must be some simple thing I'm missing. Any idea?
Ribbon example in dll
See http://www.trichview.com/forums/viewtopic.php?t=4249
Note that you can create a dll only for using in your own applications.
Making a dll that other developers can use requires a separate license.
