I use RichView 13 and ReportBuilder 14. Using the 1.2 ReportBuilder wrapper. It is a recent install of RichView13 and ReportBuilder14. I set up a new computer. Loaded Delphi 7. Loaded ReportBuilder14, then loaded RichView, RicViewActions and tried to load Report Builder Wrapper 1.2
I have tried to load ReportBuilder wrapper but when I try to load the wrapper or start my application I get the following error and warning:
[Warning] ppRichView.pas(334): Method 'AsMetaFile' hides virtual method of base type 'TppDrawCommand'
[Error] ppRichView.pas(1227): Undeclared identifier: 'TppScreenDevice'
[Error] ppRichView.pas(1227): Operator not applicable to this operand type
[Error] ppRichView.pas(1228): Missing operator or semicolon
[Error] ppRichView.pas(1229): Missing operator or semicolon
[Error] ppRichView.pas(1327): Operator not applicable to this operand type
[Error] ppRichView.pas(1330): Type of expression must be BOOLEAN
[Fatal Error] rvrb11D7.dpk(43): Could not compile used unit 'ppRichView.pas'
RichView 13 and ReportBuilder14 issues
Download non-trial versions of RichView 13.5?
Where do I download the non-trial version of RichView 13.5?
Can you send me this mail too?Sergey Tkachenko wrote:Indeed, the publicly available wrapper is not compatible with RB14.
But a newer version, available for registered users, is compatible. A link is sent to you by email (and I opened protected forums for your account).
Since i updated to RB14 no text from RV is displayed in the report.
