Invalid floating point operation
rafakwolf
Post by rafakwolf »
I get this error when i use following methods.
function GetNewStyle(rvs: TRVStyle; BaseStyleNo: Integer; FontName: string; Color: TColor;
  Style: TFontStyles; Size: Integer): Integer;
  Result := rvs.TextStyles.FindStyleWithColor(BaseStyleNo, Color, clNone);
  Result := rvs.TextStyles.FindStyleWithFontStyle(BaseStyleNo, Style, []);
  Result := rvs.TextStyles.FindStyleWithFontSize(BaseStyleNo, Size);
  Result := rvs.TextStyles.FindStyleWithFontName(BaseStyleNo,FontName);
  if (Result < 0) then
    rvs.TextStyles.Add;
    Result := rvs.TextStyles.Count-1;
    rvs.TextStyles[Result].Assign(rvs.TextStyles[BaseStyleNo]);
    rvs.TextStyles[Result].Standard := False;
    rvs.TextStyles[Result].Color := Color;
    rvs.TextStyles[Result].BackColor := clNone;
    rvs.TextStyles[Result].Style := Style;
    rvs.TextStyles[Result].Size := Size;
    rvs.TextStyles[Result].FontName := FontName;
function GetNewPara(rvs: TRVStyle; BaseParaNo: Integer; Align: TRVAlignment): Integer;
  Result := rvs.ParaStyles.FindStyleWithAlignment(BaseParaNo, Align);
    rvs.ParaStyles.Add;
    Result := rvs.ParaStyles.Count-1;
    rvs.ParaStyles[Result].Assign(rvs.ParaStyles[BaseParaNo]);
    rvs.ParaStyles[Result].Standard := False;
    rvs.ParaStyles[Result].Alignment := Align;
procedure AddRichText(RichEd: TppRichText; Texto: String; FontName: string;
  Style: TFontStyles; Size: Integer; Align: TAlignRich; Parent : TWinControl);
  mem : TMemoryStream;
  rve : TRichViewEdit;
  rvs : TRVStyle;
  lAlign: TRVAlignment;
  rve := TRichViewEdit.Create(Parent);
  rvs := TRVStyle.Create(Parent);
  mem := TMemoryStream.Create;
    rve.Parent := Parent;
    rve.Style := rvs;
    case Align of
       alrLeft    : lAlign := rvaLeft;
       alrCenter  : lAlign := rvaCenter;
       alrRight   : lAlign := rvaRight;
       alrJustify : lAlign := rvaJustify;
    rve.Clear;
    rve.CurTextStyleNo := GetNewStyle(rvs,0,FontName,clBlack,Style,Size);
    rve.CurParaStyleNo := GetNewPara(rvs,0,lAlign);
    rve.InsertText(Texto);
    rve.SelectAll;
    rve.FormatTail;
    mem.Clear;
    rve.SaveRTFToStream(mem,False);
    mem.Position := 0;
    RichEd.Text := '';
    RichEd.LoadFromRTFStream(mem);
    mem.Free;
    rve.Free;
    rvs.Free;
call this way
      AddRichText(MyppRichView,
        'MY TEXT MY TEXT MY TEXT MY TEXT',
        'Times New Roman',[],12,alrJustify, TheParentObject);
something wrong ?
thanks.
Please send me a sample project
rafakwolf
Post by rafakwolf »
i can´t...because this problem dont happen all the time
sometimes happen, sometimes don´t happen...
exists another way for do that ?
thanks.
sorry for my english! :)
This code overcomplicated. If you create a new TRichViewEdit, you do not need to use searching for styles. You can simple add the necessary styles and use them.
GetNewStyle is wrong: for searching for a style with many properties, you should use FindSuchStyle. However, it should not lead to error.
InsertText requires formatted document, so you must call Format after Clear. This is a serious bug, but I doubt that it leads to floating point error...
I'd write the code like this, see below. RTF saving requires formatting only if document contains tables, so I did not use editing methods or formatting.
procedure AddTextStyle(rvs: TRVStyle; const AFontName: string; AColor: TColor;
  AStyle: TFontStyles; ASize: Integer);
  with rvs.TextStyles.Add do begin
    Color := AColor;
    Style := AStyle;
    FontName := AFontName;
procedure AddParaStyle(rvs: TRVStyle; AAlignment: TRVAlignment);
  with rvs.ParaStyles.Add do begin
    Alignment := AAlignment;
  Style: TFontStyles; Size: Integer; Align: TAlignRich);
  rv : TRichView;
  rvs : TRVStyle;
  rv := TRichView.Create(nil);
  rvs := TRVStyle.Create(rv);
    rv.Style := rvs;
    case Align of
    rvs.TextStyles.Clear;
    rvs.ParaStyles.Clear;
    AddTextStyle(rvs, FontName,clBlack,Style,Size);
    AddParaStyle(rvs,0,lAlign);
    rv.AddTextNL(Texto,0,0,0);
    me.Position := 0;
    RichEd.Text := '';
    mem.Free;
    rv.Free;
Wait! You just need to add text to ppRichView?
You can simple add necessary styles to RichEd.RichView.Style and then call RichEd.AddTextNL, without all these difficulties.
rafakwolf
Post by rafakwolf »
Sergey Tkachenko wrote:Wait! You just need to add text to ppRichView?
exactly!
I will try...and post results later ...
thanks!
rafakwolf
Post by rafakwolf »
for what i need the RichViewEd ?
can i just use the ppRichView ?
this way
 rvs  := TRVStyle.Create(nil);
  RichView.RichView.AddTextNL(Texto,
    GetNewStyle(rvs,0,FontName,clBlack,Style,Size),
    GetNewPara(rvs,0,lAlign),0);
thanks.
Use ppRichView.RichView.Style instead of rvs.
