Hello, i saw the example of contact-list with TRichView...very good..
but has just one level on tree...and i want more than one..
it´s possible ?
thanks
Tree with more levels
This example simply recreates TRichView document every time when this "tree" is changed (expanded/collapsed, or another item is selected).
You can write your own code recreating TRichView as you need. If you need some specific example, let me know, I'll try to create.
See also: http://www.trichview.com/forums/viewtopic.php?t=62
