Justify alignment + underline texts
infrax
Post by infrax »
I have a paragraph (justify alignment) and some underlined text. Text is bigger than one line, so spaces are bigger than usual (only in this case).
When a print this on preview or PDF (pdf external libraries) the words with spaces that are underlined are printed weird. Underlines are not OK. First word is OK, but then the other lines (below other words) are not in the same level as the first line.
Example:
bla bla1 bla2 bla3 bla
Line below bla2,bla3 doesn't connect ok with line below bla1. One is lower than the other.
But if I change UnderlineType something different than rvutNormal, everything is OK.
I'm using TRVReportHelper to print.
Any idea what is going on?
Try activating RVUSEBASELINE in RV_Defs.inc
infrax
Post by infrax »
No. I still get the same result.
Check image below:
Ok, it will be fixed in one of the next updates (simple underlines will be drawn in the same way as advanced underlines)
infrax
Post by infrax »
Thx.
wanderingwino
Post by wanderingwino »
I still see same problem in RichView 14.0.3, SRichView 5.0.2.
wanderingwino
only way i see it right now to mask it is to put a _ instead of space.
