error in install FrameViewer
gbg
Post by gbg »
hi
error is : [DCC Fatal Error] FrameViewerXE.dpk(57): F1026 File not found: 'framview.dcu'
Add the path to Source subdirectory of FrameViewer to the Delphi library path (menu Tools | Options, Environment Options | Delphi Options | Library)
gbg
Post by gbg »
thanks
i download from "http://www.trichview.com/resources/html ... import.zip" and after unZip cannot find soure or dcu subdirectory of rvhtmlimport
Did you installed FrameViewerXE.dpk? It must be installed before installing rvHtmlViewImporter.
Next, you need to install rvHtmlViewImporter (not rvHtmlImporter!). Download it from http://www.trichview.com/resources/html ... import.zip
And please read ReadMe.txt from rvhtmlviewimport.zip before installing.
gbg
Post by gbg »
yes
i want install FrameViewerXE.dpk from i:\rvhtmlviewimport\html\package
Before installing rvHtmlViewImporter, you need to install HTMLViewer.
It must be downloaded separately, from http://code.google.com/p/thtmlviewer/source/checkout
And install it from branches\11 subdirectory.
If you have problems downloading it, I can send to you by email.
gbg
Post by gbg »
thanks
please send me at email [email protected]
Sent
gbg
Post by gbg »
thanks dear Sergey :wink:
gbg
Post by gbg »
when i want install rvHtmlViewImportDXE.dproj
compiler show this errors :
[DCC Error] rvHtmlViewImport.pas(187): E2003 Undeclared identifier: 'TRVTag'
[DCC Error] rvHtmlViewImport.pas(813): E2003 Undeclared identifier: 'RVEMPTYTAG'
and more error
Make sure that you use the latest version of TRichView (13.4)
gbg
Post by gbg »
i have version 13.0.1
If you are not a registered TRichView user, you can download the newer trial from http://www.trichview.com/download/
If you are a registered user, updating from 13.0.1 to 13.4 is free. Send me a private message or email (to richviewgmailcom) with information allowing to identify your order (for example, email address used in it).
