I have tried to install rvhtmlimport and am getting the following error.
[Error] rvhtmlimport.pas(2300): Types of actual and formal var parameters must be identical
[Error] rvhtmlimport.pas(2310): Incompatible types: 'String' and 'Integer'
[Error] rvhtmlimport.pas(2312): Incompatible types: 'String' and 'Integer'
[Error] rvhtmlimport.pas(2323): Incompatible types: 'String' and 'Integer'
[Error] rvhtmlimport.pas(3085): Types of actual and formal var parameters must be identical
[Error] rvhtmlimport.pas(3089): Incompatible types: 'String' and 'Integer'
[Error] rvhtmlimport.pas(3158): Incompatible types: 'String' and 'Integer'
[Fatal Error] rvhtmld7.dpk(36): Could not compile used unit 'rvhtmlimport.pas'
i have download the latest version of rvhtmlimport and also tried v034 incase that made any difference which it didn't.
Also when trying to install SRVControls I receive the following:
[Error] DShow.pas(2953): Undeclared identifier: 'LONG_PTR'
[Warning] DShow.pas(10257): Symbol 'AllocateHWnd' is deprecated
[Warning] DShow.pas(10267): Symbol 'DeallocateHWnd' is deprecated
[Hint] DShow.pas(7647): Private symbol 'SelectedFilter' declared but never used
[Hint] DShow.pas(7648): Private symbol 'CreatedFilter' declared but never used
[Hint] DShow.pas(7651): Private symbol 'UnableToRender' declared but never used
[Hint] DShow.pas(8216): Private symbol 'GetFilter' declared but never used
[Hint] DShow.pas(8217): Private symbol 'GetName' declared but never used
[Hint] DShow.pas(8218): Private symbol 'NotifyFilter' declared but never used
[Hint] DShow.pas(8220): Private symbol 'SampleCB' declared but never used
[Hint] DShow.pas(8221): Private symbol 'BufferCB' declared but never used
[Hint] DShow.pas(8299): Private symbol 'GetFilter' declared but never used
[Hint] DShow.pas(8300): Private symbol 'GetName' declared but never used
[Hint] DShow.pas(8301): Private symbol 'NotifyFilter' declared but never used
[Fatal Error] SRVMediaPlayer.pas(7): Could not compile used unit 'DShow.pas'
Error Installing rvhtmlimport / SRV controls Delphi 7
It looks like you try to compile new version of TRichView with old version of rvhtmlimport.
In the latest trichview version, items tags were changed from Integer to String. It requires changes in additional components, including rvHtmlImporter. Updated versions of additional components are available in new location. Specifically, for rvhtmlimport: http://www.trichview.com/resources/html ... mportb.zip
You can find more information in the protected "Announcements" groups. I opened protected forums for your account.
As for SRVControls, it's out bug in the latest release.
Open DShow.pas, add
in the beginning of the interface section of this file.
Open DShow.pas, add
type
LONG_PTR = Integer;
