I'm finding that the RVPrint.PrintPages method is not using the FromPage parameter - it always seems to use a value of 1. I've tried it in your Delphi/Assorted/Printing/Printing demos and the problem happens there as well. For example the following code is drawn from that demo:
procedure TForm1.btnPrintClick(Sender: TObject);
if not PreviewCreated then begin
PreviewCreated := True;
UpdatePreview;
// do not print empty document!
if RichView1.ItemCount=0 then
PrintDialog1.MinPage := 1;
PrintDialog1.MaxPage := RVPrint1.PagesCount;
PrintDialog1.FromPage := 1;
PrintDialog1.ToPage := RVPrint1.PagesCount;
// we can print a whole document or specified pages:
if PrintDialog1.Execute then begin
// it's possible that current printer was changed.
// so we need to reformat document and update preview:
UpdatePreview;
case PrintDialog1.PrintRange of
prAllPages:
RVPrint1.Print( 'Test', PrintDialog1.Copies, PrintDialog1.Collate);
prPageNums:
RVPrint1.PrintPages(PrintDialog1.FromPage, PrintDialog1.ToPage,
Thanks,
Dale
RVPrint FromPage
