Can't install in Delphi 2006
I couldn't find a D2006 install, so I grabbed the latest stable release from Oct 2005 and I tried to use the D2005 packages, but I get this error when compiling:
[Pascal Error] RVUni.pas(324): E2010 Incompatible types: 'Integer' and 'LongBool'
Not sure where the conflict is yet.
Thanks,
Tony
Thanks,
Tony
There is a "dance" in the declaration of the certain WinAPI function in the VCL source.
Initially, it was declared incorrectly (bytebool parameters instead of integers). Then it was fixed. In the next version of Delphi, they returned to the wrong declaration. In D2006 they fixed it again.
You can see conditional defines in TRichView to workaround this problem.
Finally, they have grown too long, and in the latest version I declared this function myself.
Nice, RvActions also ?
Thanks, make me much more likely to upgrade after christmas.
How about TRichViewActions, do we need a new version of them
also or just a recompile.
My projects all use both TRV and TRVActions.
Keep up the good work !
/JMA
/JMA
