Hi.
In my language in Windows 7 there are 3 keyboard types in Language bar: Standard, Legacy and Programmers.
With Legacy and Programmers there is no problem.
If I try ActionTestUni from your site Standard shows fine.
But If I download the demos (components and ActionTest) and I install and compile them, it's not working.
It shows '?' instead of some characters that have diacritics. Others are shown like it "sees" ANSI not Unicode.
Is there any special setting that I have to do so it would work..?
Thank you.
keyboard problem in Windows 7 in compiled ActionTest
The ActionTest on the site was compiled in Delphi XE. Since Delphi 2009-2010-XE applications are Unicode applications, TRichViewEdit is a Unicode window, and it accepts Unicode keyboard input.
For older versions of Delphi, TRichViewEdit is not a Unicode window, so it need to use some methods to accept input in different languages. Unfortunately, none of them is perfect. See http://www.trichview.com/help/idh_const ... input.html
