Table's intend is lost after reloading the rtf
Roliat
Post by Roliat »
Hello - it's me again ;)
Now, I got a problem with tables. When an intendation is set (for a paragraph), and a table is inserted, everything works fine. But after saving and reloading the rtf file the intendation (only) of the table is "0". Why?
Here's my code for saving and reloading
//Save
function TfrmEditor.GetRTF: String;
  ss: TStringStream;
  ss:=TStringStream.Create('');
    ss.Seek(0, soFromBeginning);
    Editor.SaveRTFToStream(ss, false);
    result:=ss.DataString;
    ss.Free;
//Read
procedure TfrmEditor.InsertRTF(rtf: string);
  ss: TStringStream;
    ss.WriteString(rtf);
    Editor.LoadFromStream(ss, rvynaYes);
    Editor.Format;
    Editor.Modified:=False;
    ss.Free;
Please help me. I use TRichView 11.05
Many thanks!
It's because you use old version of TRichView
Roliat
Post by Roliat »
Hm ... is there any way to fix this in the source or is an update *really* needed?
Unfortunately, it requires changes in several places of code, both in RTF saving and writing. I cannot say what changes are needed - we cannot support too old versions.
Send me a private message with details of your order (for example, what email was used), and I'll explain how to get a new version.
