richview1.loadrvf and filename
piet van Blokland
Post by piet van Blokland »
Hi
If I use richviewedit1.loadrvf('name file') to load a file then richviewedit1 does not remember the file name when I try to save the file.
How to change the name of the file by programming?
with regards
Piet
If you use RichViewActions, they store file names (when TrvActionOpen loads a file itself, or when you call its LoadFile method).
But if you do not use RichViewActions, you need to store a file name yourself. For example, see the demo in Demos\*\Editors\Editor 2\.
