[HOW] Import Undo
Marsianin
[HOW] Import Undo
Post by Marsianin »
Just tried to implement undo for OfficeConverters file import.
I want to import several .doc files and create undo point after each import but this seems not working:
RichViewEdit1.TopLevelEditor.BeginUndoGroup(rvutInsert);
RichViewEdit1.TopLevelEditor.SetUndoGroupMode(True);
  r:=RVOfficeConverter1.ImportRV(OpenDialog1.FileName,RichViewEdit1,OpenDialog1.FilterIndex);
  RichViewEdit1.TopLevelEditor.SetUndoGroupMode(False);
After this code I'm getting .doc file imported and undo button enabled but pressing it does nothing just disabling :shock:
Also is there a way to import file from the cursor position?
ImportRV uses RichViewEdit.LoadRTF inside that cannot be undone.
If you want to insert at the position of caret:
r:=RVOfficeConverter1.ImportRTF(OpenDialog1.FileName, OpenDialog1.FilterIndex);
if r then begin
  RVOfficeConverter1.Stream.Position := 0;
  RichViewEdit1.InsertRTFFromStream(RVOfficeConverter1.Stream);
If you want to replace the existing content:
if r then begin
  RichViewEdit1.SelectAll;
If you want to add to the end:
if r then begin
  ItemNo := RichViewEdit1.ItemCount-1;
  RichViewEdit1.SetSelectionBounds(
    ItemNo, RichViewEdit1.GetOffsAfterItem(ItemNo),
    ItemNo, RichViewEdit1.GetOffsAfterItem(ItemNo));
