table properties
Ceprotec
table properties
Post by Ceprotec »
Hello Sergey.
When we insert a table (TRVTableItemInfo) and will inserting or removing data from it, it grows and decreases its size automobile, right.
But I need to create a table with a standard size, with maximum height and minimum already defined. Regardless of how data is placed, it can not grow or diminish. I know there's a property to manipulate when the table is already created that places the minimum height. But I need to create it already set these values​​. Can you help me?
Thank you!
You can include rvtoIgnoreContentWidth and rvtoIgnoreContentHeight in table.Options. After that, the table size will be calculated basing only BestWidth and BestHeight properties of table cells.
Ceprotec
Post by Ceprotec »
Do you have examples or a manual talking about the use of tables and all properties?
