hi,
i test the exe demo"srv_actiontest"and "actiontest".there are some question need your help.
1.
i want to paste the html to richview from clipboard.how?
2. how to import a html from file.
3.
the line spacing can be setted as any number?for example,1.01 or 20.9?
thanks
regards
paste html
1-2) HTML import is not supported directly. You need to use free additional components for load or paste HTML.
They can be found here: http://www.trichview.com/resources/ :
TrvHtmlImporter and TrvHtmlViewImporter.
TrvHtmlViewImporter is recommended, but it requires additional free thirdparty component (THTMLViewer; googlecode's version is recommended). See readme.txt for TrvHtmlViewImporter.
RichViewActions support pasting and inserting HTML files using either TrvHtmlImporter and TrvHtmlViewImporter. See readme.txt for RichViewActions.
3) Line spacing, in "multiple" mode, is defined in integer %. So yes, you can define it with the precision of 2 digits after a decimal point.
(but unfortunately we have problems importing line spacing from HTML correctly with the components mentioned above).
