how can RichViewEdit document save as *.mht?
yh01110
Post by yh01110 »
the *.mht file includes images¡£
gary
Post by gary »
As far as I know, RichViewEdit can only save to html format.
See http://www.trichview.com/forums/viewtopic.php?t=11
The code for saving MHT files does not require any additional components (except for units for base64 encoding, included).
The same zip file includes examples for sending HTML emails using Indy (some corrections may be required depending on Indy version, they change programming interface often)
(another related resource - working with HTML emails using CleverComponents - http://www.trichview.com/forums/viewtopic.php?t=4123 )
yh01110
Post by yh01110 »
thank u !
here is my code
  itype:integer;
  str :string;
  Stream: TMemoryStream;
  Path, Title, ImagesPrefix, ExtraStyles, ExternalCSS, CPPrefix: String;
  Options: TRVSaveOptions ;
  bltype:integer;
  s2:string;
    s: TRVRawByteString;
    boundary: TRVRawByteString;
    i: Integer;
    slist:Tstringlist;
    ss:string;
   slist:=Tstringlist.create;
  HTMLImages := THTMLImagesCollection.Create;
   // saving HTML
  SRichViewEdit1.RichViewEdit.SaveHTMLToStreamEx(Stream, '', 'Web Archive Demo', '', '', '', '',
    [rvsoUseCheckpointsNames, rvsoUTF8]);
      Stream.Position :=0;
  SetLength(s, Stream.Size);
  Stream.ReadBuffer(PRVAnsiChar(s)^, Length(s));
  s := MimeEncodeString(s);
 // showmessage(s);
 // Stream.Free;
  // now s contains HTML file without images, base64-encoded. saving it in MIME
  boundary := '----=_BOUNDARY_LINE_';
  //AssignFile(F, SaveDialog1.FileName);
  //Rewrite(F);
  slist.add('From: <Saved by TRICHVIEW.COM Demo>');
  slist.add('Subject: MIME Test');
  slist.add('MIME-Version: 1.0');
  slist.add('Content-Type: multipart/alternative;');
  slist.add(#9+'boundary="'+boundary+'"');
  slist.add('X-Unsent: 1');
  slist.add('');;
  slist.add('This is a multi-part message in MIME format.');
  slist.add('');
  slist.add('--'+ boundary);
  slist.add('Content-Type: text/html;');
  slist.add(#9+'charset="utf-8"');
  slist.add('Content-Transfer-Encoding: base64');
  slist.add('');
  slist.add(s);
  // saving images
  for i := 0 to HTMLImages.Count-1 do begin
  slist.add('');
   slist.add('--'+boundary);
    SetLength(s, HTMLImages[i].Stream.Size);
    HTMLImages[i].Stream.Position := 0;
    HTMLImages[i].Stream.ReadBuffer(PRVAnsiChar(s)^, Length(s));
    slist.add('Content-Type: '+ HTMLImages[i].ContentType);
    slist.add(#9'Name="'+ HTMLImages[i].Name+ '"');
    slist.add('Content-ID: <'+ HTMLImages[i].Name+ '>');
  slist.add('');
    slist.add(s);
  slist.add('');
  slist.add('--'+ boundary+ '--');
  Memo1.Clear ;
  Memo1.Lines.AddStrings(slist);
