problem with Wordwrap...
CristeaTudor
Post by CristeaTudor »
Hi.
I'm new in using ScaleRichView.
For now I'm testing the trial version.
I noticed a problem:
You'll notice that on the fourth row the dot is "alone"...
You'll find the text at http://www.mediafire.com/?fl7iog73q1l6tmi
Is there something that can be done...?
Thank you.
Confirmed. Will be fixed in the next update.
CristeaTudor
Ok, I understand but when it will be available..?
For registered users - in this week.
I'll write here when a fix will be available.
CristeaTudor
So you say there will not be an update to trial versions also, so I can test myself..?
I can send an updated trial version to you by email, when it will be ready.
What version of Delphi do you use?
CristeaTudor
I personally use Delphi 2009 but we still have a lot of code not "translated" from Delphi 7.
So I guess Delphi 7 trial versions will suffice for now...
Thank you for your kind offer.
Sorry for the delay.
We fixed this bug, it appeared because of a rounding off error.
We will send a link to updated trial version to you soon.
Fixed trial for Delphi 7 is uploaded here: http://www.trichview.com/support/files/temp/rvd7fix.zip
I had to undo new beta features from this version, I hope I did it correctly.
CristeaTudor
Thank you very much.
I will try it as soon as possible.
Best regards, Tudor
