Cursor goes to top after inserting text
agent86
Post by agent86 »
Richview 13
After I add text to existing document with the following procedure the cursor jumps to the top of the document. Anyway to make the cursor go back where it was before the insertion?
procedure TRetrieveAutoTextForm.AddReplacementText ;
var Stream: TMemoryStream;
 i : integer ;
  AutoTextPreviewDBRichView.SaveRVFToStream(Stream, False);
  Stream.Position := 0;
  i := ReportWriterMainForm.rve.ItemCount ;
  ReportWriterMainForm.rve.InsertRVFFromStreamEd(Stream); // was rve.InsertRVFFromStream(Stream, i )
  Stream.Free;
  ReportWriterMainForm.rve.Format;
Do not call Format after InsertRVFFromStreamEd.
InsertRVFFromStreamEd is an editing method, it makes all necessary formatting itself.
