Word 2007 RV Export Problem in Win7
viperpix
Post by viperpix »
Hi Sergey
when im trying to Export the content of RVE in win7, the rvc.ExportRV returns false and operation becomes undone!
and one more thing..
also in win7, the Html import Capability of RVC is removed (Html is not listed in rvc.ImportConverters list, and could not import html.
thanks.
What version of TRichView and in which formats did you try to export?
As for the second question, may be you assigned rvc.ExcludeHTMLExportConverter or rvc.ExcludeHTMLImportConverter = True?
viperpix
Post by viperpix »
i had a miniature mistake for the docx export, tnx :)
but about the html, no, i didnt set those params ever,
i'm wondering why this problem wont occur in win XP !
May be these converters are not installed?
viperpix
Post by viperpix »
oh no!
how can i install somethin like "HTML converter"?!
what shall i do then?!
You can try using rvHtmlImporter or (better) rvHtmlViewImporter.
rvHtmlViewImporter may be difficult to install (see readme.txt), but it provides much better results than HTML import converter.
viperpix
Post by viperpix »
thanks by the way sergey
