Check on Jump in RVMouseDown funcrion
AVBSoft
Post by AVBSoft »
Hi Sergiy.
I use TRicView control (v10), which can contain Hyperlinks, tables with Hiperlinks
If HyperLink is outside of Table function work well.
When Hyperlink is in table, anfter run my function ("SelectCell(RVData);"), OnJump function doesn't run.
Because I'd like chech Jymp style in RVMouseDown funcrion, and can't do it correct...
void __fastcall Tm_MainFrm::m_DescriptionViewStrRVMouseDown(
      TCustomRichView *Sender, TMouseButton Button, TShiftState Shift,
      int ItemNo, int X, int Y)
    if (GetDataPtr->GetCurrentMode() != eamTestMode && GetActiveView() != eavAnswers)
        return;
    //Review mode
    if (GetDataPtr->GetCurrentMode() == eamReviewMode)
        return;
    TCustomRVFormattedData* RVData;
    int a,b;
    X += Sender->HScrollPos;
    Y += Sender->VScrollPos * Sender->VSmallStep;
    Sender->GetItemAt(X, Y, RVData, a, b, false);
[color=red]  //  Check Jump in table cell !!! ?????????????
    TRVStyle * pRVStyle;
    pRVStyle = ((TCustomRVFormattedData*)RVData)->GetRVStyle();
    if (((TCustomRVFormattedData*)RVData)->GetItem(pRVStyle->ItemNo)->GetBoolValueEx(rvbpJump, pRVStyle)) ???
        return;
???????????????????[/color]
    if (GetDataPtr->GetCurrentMode() == eamTestMode)
        HighlightCell(RVData);
        SelectCell(RVData);
    //Learn mode
    if (GetDataPtr->GetCurrentMode() == eamLearnMode)
        AnswersListShowCorrectIncorrect(RVData);
void Tm_MainFrm::SelectCell(TCustomRVFormattedData* RVData)
    if (!RVData->InheritsFrom(__classid(TRVTableCellData)))
        return;
    TRVTableItemInfo*   pTable = ((TRVTableCellData*)RVData)->GetTable();
    int                 Row,
                        Col;
    TColor              Color;
    int                 AnswerN = -1;
    CBaseItem*          pBaseItem = NULL;
    bool                bNeedUpdateAllRows = false;
    //bool
    pTable->GetCellPosition((TRVTableCellData*)RVData, Row, Col);
    ASSERT(pTable == m_AnswerTable);
............. Work with cells etc...
    m_DescriptionViewStr->Format();  // m_DescriptionViewStr -> TRichView
Do not use pRVStyle->ItemNo.
For ItemNo, use the value returned by GetItemAt(), in a variable.
