Hi
I'm actually using a non-registered version of trichview components , evaluating if they're the ones I need,using delphi 6 .
I put a trichedit component and load a bitmap image as background bit I cannot see the image, even if it is printed.
I'm sure this is a lamer question but I cannot understand why : i must see the background ...
Thanks a lot
cu
Can't see background bitmap
