Loading of RTF causes an exception
vit
Post by vit »
Hi!
I try loading RTF into TSRichViewEdit. And I receive an exception in TSRichViewEdit.HookAfterReadNote:
Debugger Exception Notification
Project Project1.exe raised exception class EListError with message 'List index out of bounds (16)'. Process stopped. Use Step or Run to continue.
OK   Help
Here is RTF that I want to load: http://webfile.ru/5268979
And here is a code that load RTF:
  SRVE.RichViewEdit.LoadRTF('d:\test.rtf');
This exception doesn't appear when I load RTF into TRichViewEdit.
Is this mistake in TSRichViewEdit or my RTF is corrupted?
Thank you!
vit
Post by vit »
P.S. You can repeat this using ActionTest
This is a bug (in TRichView code, but it appears only in ScaleRichView).
We will upload an update for registered users soon, may be today.
